Strips lots of armor(sacrifices the arms, since they're empty anyway), and doesn't go very fast, but packs a punch. Not pinpoint, but functionally slightly more damage than dual AC/20 if you can manage to stay on target for a split second longer, and has lots more range. Keeps a standard engine for more durability. Move the heat sink to the left side, and then swap in an XL for more speed and maxed out armor. You can also move two LPL into the arms that way, for more flexible aiming.
A question I often ask myself is, Can I do it any faster? Not when it comes to the bedroom, mind you, but to mechs. And in this case, I think faster would be better; for a few reasons to follow. One, you can't turn as fast with that low of an engine, and second is that your as slow as an assault with less firepower than one. So changing the weapons and upping the engine help you out a lot with this mech. Also, your head armor is far too low for this mech, as it has a sizeable cockpit for a heavy. Nowhere near as bad as the Catapult, but it's still something to consider, as going from 10% armor on the head to %100 is the difference of only 16 armor points. It is a different build, but you can easily put back your other LPL if you really need it. Mind the fact that you will lose a DHS or ammo to do so. Or Engine Rating, you do you.
SRSly? I don't think you can burn through all those ammo in a single AC10! 40 is probably enough, 60 is on the spammy side, but 90? I mean that is a high count even for a CW build. Would do this. If you want more DHS or ammo do this (swap around DHS and ammo): If you go XL it seems even more deadly with that speed...I am actually scared of this.
