WHM-6D "Laser Vom" (2x LPLas, 4x MPLas, 3x SLas, STD 280)
Thread in 'WHM-6D' started by Marukeru, Jan 20, 2016.
  1. Marukeru
    Marukeru Benefactor
    Wanted to go with something for mid/close range laser attrition. So far I have had some decent luck with this loadout, although I am debating making a few changes.
    I will often open/poke with the LPLas, and use the MPLas to work down armor or pop components. The SLas are used when my target gets a bit too close or I'm trying to crit an open component. They are also handy when trying to cool off a little bit.
    I chose to stick with the Standard engine because I find I don't personally have much luck with XLs and prefer to be physically more durable.
  2. enileph
    Had a similar idea, but was using XL, see my Night Lords build.
  3. Marukeru
    Marukeru Benefactor
    Do you mean your "Konrad Curze" build?
    I just took the idea, and swapped to have the same weapons as you with my engine. Only had to shave .5 ton of armor. Gonna test it out :)
