WHK-B "TITUS" (2x cERPPC, 4x cSRM4, 3x cSPL, TC1, cAP)
Thread in 'Warhawk Omni Builds' started by Shayu, Dec 28, 2015.
  1. Shayu
    Shayu Junior Member
    45
    Full write-up coming tomorrow. Build failed further testing.
    Basic idea is that it's a bigger version of my double ERPPC Summoner which is an offshoot of the The Hammer by Aylek. Fire the two ERPPCs simultaneously as a long range AC20; the Warhawks 24 DHS will keep the mech relatively cool while you do.
    In addition to this reliable long range punch, you're also treated to a perfectly heat neutral (once it's elited) barrage of 16 SRMs. Between the already short cooldown of the SRM4s, the WHK-B's CT quirks, and Fast Fire, this SRM barrage re-fires quickly, and it hits relatively accurately. It can also be alpha'd together with the two ERPPCs twice without shutting down (that's a total of 104 damage! enough to crack most any CT armor).
    The 3 cSPL serve as the clean up crew, putting down cored out mechs that survive barrages from your other weapons. They can also be combined with the SRM4s for some very nice sustained DPS close up.
    [Interesting little quirk about this mech, I ran out of slots before I could use all of the tonnage. 3.3 tons are still free on this build. Feel free to upgrade the SRM4s to 6s if you want more alpha for a slower refire and the loss of your heat neutrality. Similarly, you can upgrade the small pulse to medium pulse, but then your clean up weapons will start to hog heat.]
