This one is similar to the "Basilisk" build in using 4 cLRM15's, however this build focuses more on sustained LRM support and less direct fire backup. Carrying 2700 missiles it can lay down enough rain for a prolonged ranged engagement. For backup it has 2 ER Medium Lasers when something closes in, maximum armor, and a cAP help support your LRM's or deter close range ECM harassment. Depending on your team (and faith) you could technically max out your ammo to 3240 by sacrificing the two energy points and cAP... or just change one of the ER's to a TAG. Again, it's not an "All Around" build and mileage may vary depending on enemy ECM, but it's a decent support/indirect bombarder that works even better with a good spotter/narc'er.
