The Arrow "Zombie Pepper" (1xLPL, 2xML, 6xMG, 4xJJ, STD235)
Thread in 'The Arrow' started by Solahma, Jun 3, 2014.
  1. Solahma
    Zombie mode Arrow. Run around as a stick with a bite!
  2. epikt
    Do you really think you need the extra-jump jets?
    I admit I don't see much room of improvement on the default build.
  3. Excalibaard
    5,290
    Stock build is great, 4 JJ is a bit much as is the Heat efficiency, but you can edit the stock variant to mount an AMS instead:
  4. Aylek
    As this thread is basically for optimizing the stock loadout this seems to be the best place to present the following twist. This is the build I am currently using.
    I am considering switching to a STD 225, though, because this allows to remove FF from the mech, which in turns allows to switch to XL builds without spending money each time.
  5. Spheroid
    Spheroid Well-Known Member
    202
    The stock Arrow is excellent. I do agree that two tons of ammo is ideal.
    I changed the CT armor to 44/12(I may eventually go 46/10). I put one ton in the head and moved the jump jets into the torso to crit buffer the heat sinks.
    I am either going to run max jj or go down to one and run AMS.
