TDR-9SE "Cyclops" (2x LLas, 3x MLas, 2x SRM4, 3x JJ, STD275)
Thread in 'TDR-9SE' started by Cujo, Oct 16, 2013.
  1. Cujo
    Cujo Active Member
    70
    The Thunderbolt is a durable mech when used with a STD engine and Jump Jets give it the ability to navigate through hilly terrain. The 2 Large Lasers give it a solid long range hit and when the 3 Medium Lasers get in range it's even more of a threat. The 2 SRM-4 packs are good for seeking out any weak spots in armor after you been ripping into them with lasers.
  2. Npf6
    Npf6 New Member
    This is pretty much the same build I am running myself. Its very effective at close range and 2 Large Lasers means that you can still be a threat before closing the gap. I 2 SRM4's works supremely better in my opinion compared to 2 SRM6's because you cant fit as many heat sinks in.
  3. BindMind
    BindMind Advanced Member
    322
    My personal recommendation for the location of some of the components: link
    Awesome build! Nice and hurty.
  4. Aylek
    This is literally the same as one of my builds for the 9SE with only minor differences regarding MLs & SRMs and the amount of JJs. The idea remains the same, though. TDRs indeed are very durable with a STD engine, and this holds especially true for the 9SE. Lovely chassis.
    Depending on my mood I am currently switching between this build and one using double PPC + LL + SRM10.
    EDIT: Also see Blagg's Version, not differing much as well.
  5. Excalibaard
    I'd redistribute the armor a bit more onto the left shield arm. 5 of your 7 hardpoints are located in the left torso, and you can't always protects it with your right side (besides, you would lose your large lasers). I prefer to take 3 points from each leg and 5 from the cockpit for 31 armor in the left arm, enough to take a regular dualgauss or tri-ppc shot.
  6. XtopheleS
    XtopheleS New Member
    Here's a version of it with slightly redistributed armor per SubjectSeven's suggestion, plus I tweaked it to have 2xSRM4+Artemis. I feel that Artemis elevates SRM4's from shotguns to something almost pinpoint and while on paper your DPS is a bit lower due to the loss of a heat sink, it's actually much better at placing crits where you want them to go. Just my $.02.
  7. Cujo
    Cujo Active Member
    70
    In my humble opinion, Artemis on SRM-4's is a waste of 2 tons. Based on previous testing, there is no noticeable difference in missile spread.
  8. Tahribator
    Tahribator New Member
    This is an excellent build, thank you. I just swapped a JJ for a heatsink until I elite this thing.
  9. XtopheleS
    With respect, Cujo, I've done my own testing and come up with different results. At max range, 3 SRM4+A were able to core out most mechs roughly 20% quicker. For instance, vs. a Catapult it took 8 hits non-artemis and 6 hits with +A on average. In the hectic world of a brawl, this is significant.
    See this video:
    That said, if you feel there's a better use of 2 tons, that's definitely something you could argue. However, I don't think it's accurate to say it's a "waste" of tonnage. Honestly, I prefer not to take SRM's at all, currently. But if you're going to have them, Artemis is something to consider.
    Note: I didn't record this video, but it demonstrates what I already know so thought I'd share it.
  10. MadTerrapin
    MadTerrapin Junior Member
    Hi there. Confirmed that the OP's build (and the slight variations discussed in this thread) are bang on. Of the x3 TBOLTS I have, this one is the best - the combination of x2 LLAS and JJ makes this a feared beast at all ranges. Am still tweaking the SRM side of things, experimenting with x2 SSRMSs instead but that is just tweaking.
    5/5 from me.
    :phear:
  11. Cujo
    Cujo Active Member
    70
    I based my initial opinions regarding SRM-4's from this test video and from then forward from the seat of my pants in game. For my combat system and the way I play this is what works for me. Your results and opinions may be different than mine because nothing is guaranteed.
