TDR-9S "double tap" (2xERPPC 3xML 2xMG 2xAMS STD275)
Thread in 'TDR-9S' started by Lucinator, Apr 23, 2014.
  1. Lucinator
    Lucinator Junior Member
    40
    Designed for sniper support, this uses the 2 AMS's to support your team while laying down supporting fire with those PPC's in the shoulder. The 3Ml's and 2 machineguns should only be used as a last resort, or if heat management gets tricky. I did this as a replacement for my CPLT-K2 and it works much better in my opinion due to the better back up weapons and tight grouping of the PPC's so one can fire then point bank if need be and non have the damage spread out. Just remember your PPC's are mounted high up so cover is always a option. So far in battles it does decently at around 250-300 which for me is about for slightly above my overall average.
