TDR-5S V1 Unnamed (2x SRM6+A, 1x ERLLas, 3x MPLas, 2x MG, STD300)
Thread in 'TDR-5S' started by RocketRabbit, Oct 16, 2013.
  1. RocketRabbit
    RocketRabbit New Member
    Like me a little speed, XL engine is a no-go on this thing.
    Opinions?
  2. Serious Table
    102
    After not having enough speed, I went to find a 300 engine mech. This is good, frankly! I didn't pick up the Ferro, though, since I'm still fitting out Mechs with DHS...
    It runs a bit hot, so having a group to chainfire the pulses is probably a smart idea. Though this will likely get better when I finally master this mech. An alternative might be to drop the MGuns for another heatsink, but I get the feeling that Ferro might make it impossible.
    4/5 for me. Has what I want in it!
  3. drwipeman
    drwipeman New Member
    My version : less max dps and a little less armor for a way cooler build. You still can sacrifice range by using a LL instead of the erLL and get a 40% heat efficiency, but it might not be worth it.
  4. Excalibaard
    5,278
    Artemis isn't as necessary imo, but 2 SRM6s burn through 2 tons of ammo in 16,5 salvo's which seems a bit shabby.
    I swapped Artemis for yet another DHS and 1 ton more SRM ammo, giving me 25 shots. Oh and a sick sustained DPS of almost 7.
  5. Regina Redshift
    1,293
    Equipment Addict has a nice ring to it.
  6. schnaetz
    schnaetz Benefactor
    247
    My Version with Artemis and one LL
  7. Fherot
    Fherot Benefactor
    459
    86
    47
    I wanted AMS and a cool build with Artemis so I ended up using one of the stock Shadowhawk engines. Gives the 1 DHS slot, good compromise in speed and a nice dps with enough ammo and armor.
  8. Excalibaard
    5,278
    Instead of SRM6+A I downgraded to SRM4s which have innately low spread.
    Added in a lot of DHS, had 20 in an alternate build with all pulses and an XL engine but I prefer this.
