AC5 for long range fire, SSRM for cockpit rocking and anti-light capability, LLas for surgical finish on that cherry red area.
Can do with a little less speed for 2 ERLL and better heat eff for using the lasers more. ERLL are closer to the AC5 optimal range. Streaks are mostly preference, in PUGs it's definitely a good idea to have a bit of defense though most of the times you'll not use it, so it's wasted tonnage. If you DO use it you're probably in an awkward position anyway. Personally I'd go with more heatsinks and a ton more AC5 ammo instead of the streaks. Optimized Personalized: Personalized with STD engine:
