House Steiner´s signiture design overhauled to make an appearance in MWO. Recommended modules: adv. target decay, adv sensor range "Griffins Revenge" is a very mobile long range supporter for both direct and indirect firesupport. It shines while performing supressive fire dutys to hold a flank - can easyly fill the role of a scout or spotter or diversion- and can turn into a very mobile bird of prey hunting down a wounded target. Thanks to it´s long range and impressive jumping capabilities combined with good speed it can help out wherever it is needed on the battlefield. It´s alphastrike may be low but the abillity to fire repeatedly without shutting down makes more then up for it. The combinatition of PPC + TAG helps your lancemates a lot when facing ECM. If you want to make the most of the design do not waste to time with a single enemy and fulfill your supporter role instead - this mech allows you to have a great combatoverview - make use of that and help your comrades - flank, cover their blind spots and add your firepower to focus down targets or distract some opponents from joining the main battle.
Thanks guys - much more convenient to look at. Arm weaponry, armor and ammo ditribution can be adjusted to personal taste but you hit it quite well.
