TBR-P "Wumber Wolf" (6x cMPL, TC3)
Thread in 'Timber Wolf Omni Builds' started by Motörhead, Oct 16, 2014.
  1. Motörhead
    @Solahma reinforcement version, not released for cbills yet
    One of the lasers clan features is "the damage is big but needs high exposure time, and long beam duration can spread it".
    cERMPL range module is needed, and so the CD.
    TC3 for even more range and all the other bonuses.
    3JJs are nice for mobility, since the mech can afford them.
  2. schnaetz
    schnaetz Benefactor
    247
    I'd downgrade to a TC5 (and lower armor if you really also want to keep the cAP) and put in more DHS, especially with a level 5 cMPL cooldown module (3s - 0.36s = 2.64s):
    Full Damage Range: (330m + 20m [Range Module 5]) * 1.12 [12% TC5 Range] = 392m
    Max. Damage Range: (660m + 40m [Range Module 5]) * 1.12 [12% TC5 Range] = 784m
    even more Wub (but ghost heat), TC2, no cAP:
    Full Damage Range: (330m + 20m [Range Module 5]) * 1.085 [8,5% TC2 Range] = 379,75m
    Max. Damage Range: (660m + 40m [Range Module 5]) * 1.085 [8,5% TC2 Range] = 759,5m
    As you can see, the difference in range is pretty small and should not be an argument. Faster target information an additional crit rate however needs to be considered.
    Will test that this evening
  3. aktionsandi
    aktionsandi Benefactor
    I just played 3 matches and it has a nice feel to it, pretty brutal. I downgrated the TC7 to a TC5 to add 2 more DHS though. The heat ist very manageable.
    Now Im going to play a couple more matches to see if I like it more than the 2x cLPL, 5x cERML build
  4. schnaetz
    schnaetz Benefactor
    247
    2LPL + 4 or 5 ML is the build I also had in mind when thinking of similar loadouts....more range, longer beam time
  5. Solahma
    I'll give this build a go, you know I can't resist a new Wubly mech build ^_^
    Seems like interesting benefits over the Stormcrow 6 cMPL build. Better cooling, jump jets, and a large targeting computer. Looks VERY attractive actually, nice idea!
  6. Motörhead
    yeah the cooling can be tuned, not having the mech does not help, so testing and adjusting is something I can't do yet !
    Do you have the MLP range module too? how much range does it have?
    The 2 LPL 5 ML is sure a great build, but I tested the 6 MPL stalker, I've seen Solahma Wubanshee results, I like the med pulse lasers a lot in IS, even tho the damage can seem lower, so in clan you actually land it almost always all while esposing for a minimum time (even less then IS standard lasers) but also fix all the problems IS have, at least that's the idea :) (the stalker lacks a bit of speed, so does the banshee and uses an XL, the timby can use a clan XL, plus the JJs, and the range from clan MPLs)
  7. schnaetz
    schnaetz Benefactor
    247
    In case TC is multiplicated after adding range modul
  8. Pasternak
    Pasternak New Member
    It was a build I was using a few weeks back, between the range module and the targeting computer you get some good range on the MPLs, it makes a nice brawler with a good punch. I eventually went back to the 2xLPL 4xML build though for the extra range.
  9. schnaetz
    schnaetz Benefactor
    247
    I'm using this as my current laserboat since LPL+ERML has become even hotter ... If mastered 7MPLas can be handled with no problem just by having 2 weapon groups for torso and arm lasers. I've got no cooldown module yet, maybe I will switch back to 6MPLas then.
    Just had a 1441 dmg game without arty/air strike (sorry no screenshot)
  10. schnaetz
    schnaetz Benefactor
    247
    Well, I bought the cooldown module and I'm still runing 7MPLas. Yes, its more heat but man it's also more wub and fun .... components flying around everywhere!
    Until you have unlocked double basic skills / mastered the mech, I would go for 6MPLas + TC3 or TC2 on the Timberwolf S.
    If you have no Thunderbolt SS, then this is your clan version of it. Im playing with two friends (2x Timber + 1x ThunderboltSS) and it's a constant wub-party in voicechat.
  11. Motörhead
    My final version, also edited the title.
  12. Remarius
  13. Solahma
    Motörhead likes this.
  14. Motörhead
    Ahah I didn't notice :)
    @Solahma version is better, heat improvement is welcome, because it does run hot even with a lot of DHS. 2DHS and +5% must be a huge boost.
    Since is not free 2 play, I'll split the 2 versions for now, and then replace it when it will available for cbills.
  15. arrgh
    arrgh New Member
    Simple, but effective. I´m still figuring that new TBR-A LT omnipod out.
  16. Madgoose
    Madgoose Well-Known Member
    Your link doesnt work for me.o_O
    "Just" post your smurfy's as everyone else does...^^
  17. Haike
    Haike New Member
    Updated your arm to a TBR-D arm for 5% heat generation quirk. That 5% matters :)
  18. arrgh
    arrgh New Member
