This thing is great. Works wonders on test sever. JJ ability is provided by the LT/RT of type S. Or you can use the C type CT for an extra CERMLas. Changed some settings due to JJ changes. Downgrade to SSRM4 as they are more functional. Config S is shit now. Avoid.
Was a bit hot for me, so I went for cSSRM4 and gave your build a 4/5 (too much heat management at least for me ): I'm still not sure if I want cSSRM-Cooldown or cERML-Range
After the latest patches, this build is now a couple tons over limits. Here is a redesign I had quite some fun with: Not as effective as a pure laser vomit against heavier target, but seemingly a decent compromise for everyday use.
The fact that I did more than 1000 damage in the span of 4 minutes is a testament to this build's raw power. Granted I didn't get very many kills but ya know, wrong place wrong time. The ssrm's make taking care of the little one's that come near you a pleasurable experience because it only takes a few salvos granted that your 5 mlas don't massacre them before you get the 2nd one off. Truly love this build, well done. 5/5
Different version I've used quite a bit in the past and I'm surprised its not listed. Its very much an aerial combatant - constantly moving and raining down damage from above. Quad arm mounted ERML with lower arm actuators for targeting, triple torso CSSRM6 launchers with cAP to bypass ECM and 4 jump jets. Its very easy to cause chaos and pare away defenders for your team to focus down with this build.
