TBR-P "Ace of Spades" (PRE-NERF BUILD - NO LONGER VALID)
Thread in 'Timber Wolf Omni Builds' started by Puppeteer, Aug 2, 2014.
  1. Puppeteer
    Puppeteer New Member
    This is my newest build , since module patch went live. Patch also brought some corrections so now cSRM6's with cSRM4's will generate ghost heat when fired 3 or more at same time. So i decided to go full out generate as much dps and alpha as possible. With 108 alpha this mech is a killer, which comes at the cost of ammo and heat efficiency.
    Ace of Spades achievement unlock in this game :
    [img width=700 height=437]http://i.imgur.com/Fu6vRhW.jpg?1[/img]
    Weapon Grouping:
    Grp 1: 3x cERLL
    Grp 2: 2x cERML
    Grp 3: 3x cERLL on chain fire
    Grp 4: 4x cSRM6
    Grp 5: 4x cSRM6 on chain fire
    Grp 6: 3x cMM
  2. enileph
    Not enough SRM ammo I think, You might drop the MG for more ammo.
    Need a bit of armor on the legs.
    I swap some parts and downgrade a cERLL. But you get more armor, and mid-close range damage is similar. Your illusion of higher DPS comes from the MG.
    If you really want to keep your chicken thin legs then you can get more DHS.
  3. Solahma
