TBR-C "360 No Scope" (1x cGauss, 5x cERML, TC6)
Thread in 'Timber Wolf Omni Builds' started by zak2501, Jul 9, 2014.
  1. zak2501
    zak2501 New Member
    Fun build, I have tried a bunch of other gauss rifle combinations on the Timber Wolf but I have found that laser's compliment the gauss rifle better than cERPPC's. I think it's mostly because of the pinpoint damage you can do with laser's, especially if your good at damaging one spot. The targeting computer MK VI help alot with cERML's range and crit chance making it a very effective weapon with a gauss rifle. Make sure you have the Lower arm actuator ticked on the left arm.
    I seem to be getting good kills and damage with this build so I think I will keep it as my TBR-C variant and share it with you guys.
    Weapon Groups:
    1 - 2 cERML's (Left arm)
    2 - Gauss Rifle (Right arm)
    3 - 3 cERML's (Torso)
    4 - 5 cERML's (Chain Fire)
    Some Strategy:
    I like to peek my right arm out around corners and nip people with my gauss rifle and use my torso ErML's as I am backing up to blind them from any return fire.
    TC1, JJ, 21 HS Variant:
    By dropping a heat sink, lowering the targeting computer, or removing it you can get a max armor version or even a jump jet version.
    In game name: Skylen
    [size=18pt]Here is some other variants that can be done with the Gauss Rifle in the Right Torso
    6 ER Medium Lasers, 17 Heatsinks, & TC6 Variant: (remove lasers or lower the targeting computer level for more ammo/DHS as you please)
    7 ER Medium Lasers, 21 Heatsinks, & TC1 Variant: (remove lasers/DHS for more ammo as you please)
  2. zaepp
    zaepp Junior Member
    40
    Yeah, times change and indeed, since the PCC/cERLL-nerf everything works good with cERML. I'm just waiting for the next nerf.
    I build it like this:
  3. Abigail Acerose
    Abigail Acerose Active Member
    59
    And I build mine like this:
    It's excellent fun, even when you die! Though I was the only pilot on my side to break 400 damage... =P
  4. schnaetz
    schnaetz Benefactor
    247
    I'd use 1/2 ton-Ammo for critpadding:
    You could also go full prime variant (if you want the quirks and no JJ):
  5. zaepp
    zaepp Junior Member
    40
    [quote author=Abigail Acerose link=topic=7339.msg51180#msg51180 date=1408661358]
    [/quote]
    I would not recommend to put that Gauss into your RT, because:
    - As soon as your RT is opened up, the Gauss acts like a giant crit-seeker and will most likely explode
    - You not only lose your Gauss, but your two ML as well
    - You increase the likelihood to lose one of your STs by a large margin
    It's basically like six slots full of (explosive) ammo, and two slots of crit-padding with Gauss-ammo can only help so much.
    Put it into the RA instead.
  6. zak2501
    zak2501 New Member
    is 7 medium lasers worth it?
  7. Solahma
    Probably not, 6 cERML is already hot, 7 would trigger ghost heat... 4-5 seems to be best. 6 is pushing it.
    I would consider 6 cERML, a TC1, and a JJ in this case
  8. The Verge
    GAUSS AMMO DOESN'T EXPLODE! ONLY THE RIFLE!
  9. Solahma
    I'm pretty sure this is what he is saying Verge :mellow:
  10. Lan
    Lan Mech Wrangler
    1,570
    Pay no attention to Vergere, he's been drinking coolant again I think. ;)
