Casual STK-M Misery "Mis(t)erio" (3xLPL, 1xAC10, 2xML, LE300) + alts (LBX10, AMS)
Thread in 'Misery' started by CarloArmato, Sep 9, 2019.
  1. CarloArmato
    Pinpoint-ish oriented version of the misery
    The biggest key features is being an overall symmetrical build so a side torso loss won't be an issue: if you lose the left side, most DHS are on the right side, so you can keep on hammering those 3xLPL without incurring in heat issues that much. If you are gonna lose the right side, an AC10, LPL and 2xML should be manageable and you still have 30 dmg alpha strike. This build tend to be bit hotter than expected, so don't shoot those 2xML if you are close to overheat.
    EDIT: on a side node, it could be worth considering moving one DHS from the left arm to the right side... Right side will tend to be a lot hotter than expected with almost no DHS left.
    ALT: switch the AC10 for an LBX10. With an additional slot and ton to play with, you can straight add a TC1 or fit an AMS while dropping that half ton of AC10 ammo (IMHO 2 ton of LBX10/AC10 ammo will suffice even for long matches)
