STK-3F TheOverlyAttachedGirlfriend (4x SRM6, 4x MLas, 2x Flamer, AMS, STD300)
Thread in 'STK-3F' started by Auron Sangius, Jun 19, 2013.
  1. Auron Sangius
    Auron Sangius New Member
    I present to you the Overly Attached Girlfriend! Once it latches on to you, it never lets go and makes you melt! Flank the enemies and surprise them with you insane close range punch. The flamers effectively disable any mech that wants to counter attack you and when you just let go of your SRM6s with your lasers, they simply fall. I do not even need to mention those ERPPC builds out there.
    The suggested weapon groups are as follows:
    1: chain fire 4xMLas
    2: chain fire flamers
    3: 4xSRM6
    4: 4xMLas
    just hold MB 1 and 2 for heat & dps efficient MLas + Flamer combo, MB 3 for your actual killers and hit 4 occasionally to target those that are out of your killzone. Little to no heat management is required for this build.
    The inability to see and constant damage display caused by flamers tend to make pilots panic and they start to make huge mistakes. This mech truly inspires fear when encountered on the battlefield.
    Share your thought please :)
    P.S.: Just really go in for the hugging distance for best results. It has the engine capacity for it.
    Edit: Alright, SOME heat management may be necessary. :phear:
