STK-3F Alpha Much? (4x SRM6, 2x PPC, 4x MLas, STD300)
Thread in 'STK-3F' started by IanSane, Nov 20, 2013.
  1. IanSane
    IanSane Advanced Member
    339
    If I am cool I nuke close targets for 88 damage (enough to 1 shot some mechs) otherwise I use it as a second line fighter. Sticking to the 4 medium lasers and SRMs for close in brawls you still get massive firepower with good heat (43% cooling) then back to your PPC for mid to long range engagements where your SRMs can't reach (38% cooling with Lasers and PPC). For very long range fights you can spam your PPC quite easily for almost a minute (69% cooling PPC only). The trick to this mech is to break down your fight into 3 arenas. Over 360ish meters PPC only, 270 meters to 360 meters PPC and MLas, below 270 Meters SRM and MLas only unless completely cool (< 20%) then you can use your nuke which will take you to about 60-65% before switching back to Mlas and SRMs.
    Nearly cored a Thunderbolt from 100% at 120 meters with a single alpha. 1 follow-up shot from a single SRM6 finished him.
    By request. Its the Big Mouth! Not a very high scoring game but everything was dying too fast. Still gives a good feel.
  2. Blagg Zear
    holy sh*T! What an I*nSane Alphafirepower! Despite the low Smurfy Cool Efficiency, you just need max. two Alphastrikes to kill any Enemy. If it only had Artemis.. :rolleyes: Damn, need to test it!
    my first thought to find a build to compete with yours would be this:
    :rofl:
  3. IanSane
    339
    Thanks Blagg :) Hopefully Michael will post the video soon in the user section then you can see it in action. It nearly tore the shoulder off an Atlas with 1 shot and the only reason it didn't is because we were both moving and I couldn't get a good bead on it. Another shot completely stripped an assaults front armor off with 1 shot. Using Smurfy I found that the Alpha heat from both your mech and this one are roughly the same. The ghost heat from the large lasers and 4 SRM 6's equals about 76% of your cooling capacity per alpha. And this one its 74% because the only ghost heat is the SRM6s
  4. Blagg Zear
    Wow, sounds like your testround was a mindblast!
    If the Alphaheat for both are similar, it's only a question if ya wanna snipe with Double PPCs at a bit more distance (but with limited min.Range!) and finish off Targets below 270m, or if ya wanna have constant LLas.beams at Mid Range. I think both builds have their strengths.
  5. IanSane
    339
    Oh they definitely have their advantages. Give you an idea...I only hit 5 mechs before the match ended and still walked away with over 600 damage.
  6. Blagg Zear
    hmmph, what do you think, is it better to have a 88 Alpha-Damage for two Shots = 176 Damage, or something lower but enough Cooling to have 3+ Shots? Let's look at this build:
    No Ghost-Heat! 64 Alpha-Damage for three Shots = 192 Damage. The Trade-Off is clear: You need time for the third shot, so probably taking more enemy-counterfire in the meantime, but at least not OH so fast. :rolleyes:
  7. IanSane
    339
    OOOH! OOOH! AND it has Artemis AND no ghost!
