Hey Guys, I put this build together, and found it to be very effective. Lemme know what you guys think, any and all advice is appreciated. Note: I also messed with taking a JJ off, and adding AMS as well.
Well, for a start you have 16 slots free, so there's no reason not to put Ferro-fibrous on it. That gives you some extra tonnage you could use to go to a Std 290 or 295 (with some armour shaving), or grab AMS. I'm running a very similar loadout on my 2H at the moment that I'm really enjoying so far. I just use a LPLas instead (which is something else you could use the extra tonnage from FF for). I played a couple of games with a Std and although it was very survivable, I found it too slow (at least until I get it Elited) and ended up moving to an XL. The extra speed is great, and the XL is not much of a liability in the SHD. As far as the "big gun" goes, personally I think either a PPC/ERPPC (if you wanna have the range) or a LPas (if you're happy getting in the brawl) would be better. The LPLas with this loadout is great for hunting lights. I'd probably only go ERLLas if I was trying to fit an XL360 and go for max speed (see below). This is purely opinion though. Check this thread for ideas, if you haven't already: SHD-2H Megatron. Similar builds are discussed and an ERLLas version is mentioned. My 360XL version:
