BAP is on there to shorten the SSRM lock time and to target shutdown mechs with the SSRMs. Here is an LB 10-X AC version. Has an extra heat sink in the engine.
Just so you know, BAP actually doesn't shorten the lock-on time for the streaks. I thought (and hoped) so too... Still increases sensor range and cancels ECM under 150M so its still handy. Doesn't change the fact that this is still a good build.
Whoops I was wrong. https://mwo.gamepedia.com/BAP Anyway, the ECM cancel and sensor range boost was handy, as you pointed out. I took out a DDC at close range on Tourmaline last night. It was over heating badly and kept shutting down. I was able to keep the 15pts of damage per salvo from the SSRMs until it died. It was getting the AC and ML too, but half of this mech's damage potential is robbed when those SSRMs don't fire.
