SHD-2D2 Whats Backup (2x LPLas, 3x SSRM2, 3x JJ, XL325)
Thread in 'SHD-2D2' started by HowsMyAim, Nov 16, 2013.
  1. HowsMyAim
    HowsMyAim New Member
    just testing with the shadow hawks waiting for them to come out.
  2. HowsMyAim
    forgot the duel heatsinks
  3. Michael
    Its also in the wrong section. That is a 2D2 build you have in the crib sheet.
  4. BoldricKent
    BoldricKent New Member
    With the latest updates on Pulse lasers, i thought i might give a bigger one a chance.There is few
    shortcomings in this design, speed since it is under 100, light on ammo, but i usually run setup 1 ton
    ammo less then number of launchers. You get caught running dry sometimes, but not to often.
    And Heat, i haven't run dual LPL on any of my mech, so im a bit in the dark.1 works really well on
    2H with 3MG,3SSRMS. Its also my first XL build out of 5M, both 2H and 2D2 run on STD.
    So i need an opinion on the link below, before spending money on XL, thx.
    ADMIN EDIT: Fixed the build and the subject line. Please read the FAQ on build posting guidelines to prevent future posts from being deleted.
  5. Excalibaard
    5,278
    Welcome to Mechspecs but please:
    Read the FAQ/rules, use 'smurfy tags'.
    That results in this:
    As for the build itself I find it too slow. I run 4xSSRM2+2xLL with an XL325 and I don't find it worth sacrificing a launcher, ammo, speed to get 4 tons and reduce the burn time of the large lasers a bit. The range is also still lower than regular LL.
    HOWEVER: the XL300 is a great engine for a lot of other builds (as is the XL280 and XL255). You get a free XL300 in the Centurion 9D if you were planning on getting centurions at some point in your mech bay.
