Just a basic build that should run decently well. 180 rounds will last you for 60 shots ERPPC should last for significantly longer. You have the speed of a fat light mech, ECM to take the heat off or distract enemies Stay in UAC5 range, but don't get too close. EDIT: Cooler, loses 2 pts alpha
I watched this in use a few times today (after I had perished). I was surprised at the sustained DPS of it, despite only having 2 weapons systems. It was impressive. My only thought, is I would personally move the PPC to the right shoulder, for more sniping power, take armor out of the left arm, and put it back in the legs. I don't like how squishy you have those. All in all though, it looks like a build well worth trying.
The Shadowcat is Hard To Make A Good Build PGI Either Needs To Take Away Mask Or Jump Jets Out And Also Have More Weapons Upgrades Hard Points
Tom, you just halved the ammo count to get that. You can shave armor off that arm instead since you don't carry a weapon there, bring the legs back up to a decent amount and still keep all 180 rounds. Also, This Is Very Hard To Read.
Primary reason for the arm weapons and not shoulder is so the weapons are synced at all times... especially in CW where you might need to fire an alpha at a guy above or below you
