SCR-P "U Wub M8?" (4x MPLS, 5x SPLS, TC1)
Thread in 'Stormcrow Omni Builds' started by GrnMonster, Apr 22, 2015.
  1. GrnMonster
    GrnMonster New Member
    This build is awesome for mid-game to late-game. Bring the 5x MPLS range module to give yourself some early game range.
    Be very careful with alpha strikes. On cooler maps, when you are at 0% heat, you can alpha and it will put you in the 70-75% heat range. On hot maps an alpha strike from very low heat will put you in the upper 90's or possibly shut you down.
    I've found that the heat is very manageable with this build. Firing the 4 MPLS, then all 5 SPLS seems to work well. If I do start getting too hot, I've found that I can toe the line fairly easily by alternating the two SPLS weapon groups during a close in brawl.
    Weapon Grouping
    • Group 1 - 4x MPLS in the left arm
    • Group 2 - 2x SPLS in the right arm
    • Group 3 - 3x SPLS in the torso
