I have seen some LRM builds on here but here is my take! I find that artemis makes a big difference on clan lrms but dont see it too much on the builds posted here. I dont spam lrms alot, I take the shots I know that will most likely connect. With that play style i dont run out of ammo too often but i find the the clan smalls are a great backup. They can do max damage at 180 right when you cant use the missiles and 4 together is still minimal heat while having that short beam 20 damage knife to cut anybody that gets to close. This build can get a bit hot if you are firing all 3 lrm15s together but you can still get several shots before you need to start the chain fire. Use your 100kph to get a good firing solution and seal the deal. I normally run about 400 to 800 damage with this build and have hit the grand line.
