Real simple on this one. This Crow is a support build. You have 2 long range weapons weapons to punch enemies from afar, and swap into the Medium Lasers when they get close or for precision targeting. The largest problem with this build is heat. Each PPC generates about 20-25% heat, the lasers generate a little less. When in combat you can fire both PPCs 2 maybe 3 times depending on how long a lull you wait before you must cool down. Gives a pretty mobile platform with decent armor and 2x ppcs can be enough to make some heavies think twice about advancing. Also makes a good counter-light. Just don't go brawling or you WILL shutdown. The left arm does give some negative energy quirks, but i think considering how hot this build can run (generating 40-50 heat per PPC strike and 20 per 3x laser strike) having some longer cool down isn't terrible.
