SCR-C "Wang-Bane" (1x cAC20, 4x cERML, cAP)
Thread in 'Stormcrow Omni Builds' started by The Verge, Jun 17, 2014.
  1. The Verge
    Fixed loadout, more fun stuff. CAP this time. Don't forget, you only need the Prime head and the C chassis to make this. Also, 105 shots? that's good, but this is better
  2. BindMind
    BindMind Advanced Member
    322
    Heat sinks in the engine are fixed and cannot be changed I think.
  3. Tristan Lorius
    Tristan Lorius Active Member
    drag the heatsinks OVER the actual Heatsinks 0/3 text :)
  4. The Verge
    No shit, Smurfy was broken the day clans came out. But thanks for the heads up, I've fixed it, and removed the useless TC.
  5. Solahma
    FYI, 105 rounds = 26 shots in 4 round bursts. Might be enough for a round, but definitely will run out in a lot of matches. You've probably discovered this already.
  6. Forte
    Forte New Member
    UAC 20s are 5 round bursts so that is 21 shots. Which is the same as 3 tons of IS AC20 ammo.
  7. Solahma
    oops, you are correct: 5 round burst @ 4 dmg each.
  8. Thiak
    Thiak Well-Known Member
    244
    nice one, i'd rethink for this:
