RVN-3L "Rapturkey" (1x SRM6, 3x MLas, 1x SRM2, ECM, XL295)
Thread in 'RVN-3L' started by Tyr4nt, Aug 23, 2013.
  1. Tyr4nt
    Tyr4nt New Member
    After having spent some time piloting Jenner's, this build drops the SSRM's and 1 heat sink to pack more punch.
    *Note: If you have trouble connecting with the SRM2, try assigning it its own weapon group. If that doesn't work, if nothing else it's extra firepower to let loose on bigger targets.
  2. PilotSerenity
    PilotSerenity Well-Known Member
    106
    The fun starts when you mastered it
  3. The Verge
    this is my EXACT load out. Stop spying on me in my cellar.
  4. Tyr4nt
    Tyr4nt New Member
  5. Marcti
    Marcti New Member
    Looks good , will it be okay without artemis?
  6. Blagg Zear
    This is a copy of my Skirmisher Build!
  7. Marcti
    Marcti New Member
    yep it is!
  8. Blagg Zear
    Bad boy you.. :phear:
  9. Tyr4nt
    Tyr4nt New Member
    I looked for a 3L with this setup before posting it and nothing showed up. I honestly didn't see it, but now it's showing up. It honestly wasn't copy though, it just worked out that way. Our builds are close so I can see why it would seem that way. But it's not an exact copy, your armor allocations are lower on the legs and higher on the arms and carries either 1 ton more ammo or a BAP instead of the heatsink in the engine.
    In either case I'm fine with my build being merged with yours, I do prefer my setup though. My build has more armor on the legs, you can live if you lose an arm but not a leg. Neither of your builds have the DHS in the engine. Maybe it's just me but in your BAP build I would probably lose the BAP and put on AMS instead but that would be my priority.
    If I had seen your build I would have posted mine to your thread as how I would run your* build. This is how I run mine*
  10. Blagg Zear
    dont worry.. i like your mod! honestly ;)
  11. Marcti
    Marcti New Member
    Its blagg's build idea , but yours is a variant , both are good anyways, hopefully a mod can merge this!
  12. Blagg Zear
    Id rather say we had the same (weaponloadout) idea. ;)
  13. Kryten 2X4B
    Kryten 2X4B Active Member
    I am really satisfied with your build, can do lot of damage...
    Here is my version, that 4srm in 1 tube is not so bad as it looks...
    update: switched back to srm2 with 400 ammo...
  14. Kryten 2X4B
    Really funny build, thx for idea...
