RVN-3L "Dive Bomber" (1x SRM6, 3x MLas, 1x SSRM2, XL295, ECM) *updated 12/31/13*
Thread in 'RVN-3L' started by LungButter, Mar 13, 2013.
  1. LungButter
    LungButter New Member
    Has a slight overheating problem with constant fire, but isn't crippling, does wonderful damage if you can pinpoint your SRM6 hits with the lasers.
    Name says it all, really. "Dive Bomb" your target of choice. Get your SSrm2 Lock, close in on them, pop your SSrm2, lasers, and then before you fly past them get a close range shotgun blast with your SRM6. Circle around, repeat. Always stay moving. I try not to drop below 80KPH if i can help it.
    Fun Mech, Fun build. Give it a try and let me know what you think. All criticism welcome.
    New Year Edit:: Drop 1 Heatsink, put in a XL295. 150kph top speed.
  2. Mythweaver
    Mythweaver Advanced Member
    400
    Decent Build. This is where I started with my RVN-3L, I liked it well enough but made changes over time. I think this will be a successful build for alot of pilots. It gives you options in situations where your ECM Suite may be outnumbered and should provide good damage from match to match. I made my changes because I was constantly searching for a better average Damage. Have fun with this build.
    Mythweaver:smile:
  3. LungButter
    What changes did you make to yours for better average damage if you don't mind my asking?
    thanks for the compliments and rating, too!
    -Blood
    ETA: Going back and checking the 3L forum, your "optimized" build is actually what i used as a guideline for my build. :) cheer!
  4. Mythweaver
    400
    My current build is posted on this Thread. I average 500-600+ damage. Today I had my highest damage output to date...810 points. I was out of SSRM's and had very little armor left but that damage and the 5 Kills that went with it made me feel like I was doing something right; for once.
    Myth.
  5. UntamedZer0
    UntamedZer0 Well-Known Member
    215
    I ran Myth's 3L build for a long time very successfully. Then I found my OCD winning the fight with just 2 missiles coming out of a 6 rack. I did a little moving around to a set up similar to this one but a hair different. I am finding that I like having the 6 rack option and I am liking what I am seeing with this build.
  6. Mythweaver
    400
    OCD? Obsesive Compulsive Derangement?? LOL:tongue:
  7. UntamedZer0
    215
    It wouldn't be so bad if the looks changed if you didn't have a certain piece of equipment equipped. If the 6 rack turned into just a wall of armor or just the appearances of a small 2 port rack it wouldn't be so bad.
    Derangement sounds about right though.
