This build has worked great for me. In the alternative, drop the extra DHS for another ton of SSRM ammo.
Nice build . I pretty much run the same build for my #1 Raven . Different armour config , 1 extra ton of streak ammo instead of the double heat sink and swap out the tag occasionally with 1M las depending on how I feel . With the recent lrm buff the tag is pretty helpful . thumbs up
You don't need BAP in addition to ECM for your Streaks to work. Anybody criticizing a good build such as this one should look up the game mechanics first. Please review your rating if you downvoted the build because of this. Anyway, the combination of double MPLas and double Streak will deal a lot of damage, and the addition of TAG allows for better scouting and LRM support. The only thing I'd change is removing that DHS (or at least place it in your RA for crit padding) in favor of another ton of SSRM ammo. A well rounded package in my view, and even capable of using the largest engine possible. I am not sure if it's worth 5 stars in the current meta, but it's 4/5 from me easily.
What does BAP do for Streaks anyways? Unless you want to hunt shutdown mechs then ECM+TAG can do anything you need. TAG can lock under ECM, and ECM can definitely counter ECM.
