Meme RGH-BLT "Bullet Barrage" (4x RAC2, LE250)
Thread in 'Bolt' started by Ven, Jul 25, 2026 at 8:51 AM.
  1. Ven
    Ven New Member
    rgh-blt
    Skills: af715cd98354a20670a49cdf56f0480020c0400008066125b2fd7f4202018
    Suboptimal, stylish, infinitely fun and surprisingly effective build (sometimes).
    Unlike its bigger brother Nightstar the mounts are better and tightly grouped around the cockpit so you can flex with your spinning barrels at will:D
    Available tactics:
    1) Shoot groups of 3 rotaries at the same time for the short engagement.
    2) Shoot 2 rotaries from the each side torso for the infinite suppression fire. Zero heat.
    3) The "Stare of Death" alpha with all 4. Ghost heat can be generally ignored - your opponent will be cored before you run out of your heat anyway if didn't spread the damage. After that you will likely overheat and jam so choose the opponent wisely unless you plan to go down together :)
    Peek the hills, hold your ground and avoid UAVs as your arms are not shooting! At least 1 coolshot is required!
    Ra-ta-ta-ta-ta!
