So this is a build I did not expect to work when I first started on it. After a few tests, I find it works rather well. The AC/20 does not have a lot of ammo so it would be a good idea to save it for the heavier mechs. while the extended range large laser has enough damage when combined with the twin medium lasers to handle the light mechs. A lot of builds tend to go with an XL engine because of the reduced weight. The fact that it kills you when one of your three torso's are taken off was something I did not like. With the energy weapons it has on board running out of AC ammo should not be a problem. Heat management on it is decent enough to where you will not have to worry about it at all times. However some of the hotter maps will cause problems if you are constantly firing your weapons. even if you have heat containment and cool run. The weapon groupings I like to use are 1: Medium lasers 2: AC/20 3: Extended Range Large Laser
