Ok, last build for this chassis from me. PROTECTOR It is what the name suggests, a high alpha damage monster. No boating any weapons, Good heat efficiency considering what you are using. The missiles were sacrificed in order to maintain a much stronger long range alpha strike. Only real downsides to this guy are if you dont like this playstyle and he has no JJ to help with the "sniping." Good thing this guy isnt a true sniper. Hes just meant to come around the corner and blast to hell whoever is in front of him, similar to a stalker. Weapon convergence may be an issue, but luckily the main points of killing damage wont have that big of an issue. Grouping goes as such: 1. Gauss 2. PPC 3. LLs 4. Alpha OR This is what i would use 1. Gauss+PPC 2. LL 3. Alpha Just try to keep guys from getting within that 90m range PROTECTOR Heres the XL version posted to the OP for easier access.
Yeah much better! But why strip Armor from your Arms+Torso? Id strip from Legs and maybe a bit from Sidetorsos.
Just preference. This guy is so easy to CT kill it almost doesnt even matter where you take it from. I could probably walk around with 1 armor in my head and be just fine.
Well still you shouldnt strip armor from CT. And cmon replace the OP with the XL mod! STD version is too slow.
No. some people just prefer having a STD engine, like this guy. You're right on the CT armor though, ill fix that.
