Patch #21, v1.4.302
Thread in 'MechWarrior Online' started by Lan, Jul 2, 2014.
  1. enileph
    I have a CC. It seem that not all mech can mount a CC though.
    Well, at least I know my Atlas can mount it, but it does not show up on other mech. Then again they say something about it not being purchasable yet when they are running the trial.
    As for the UI. I love the new mech selection screen! Loads much faster! Then again the loading of mechbay should not be slow to start with, they should not penalize people with more mech by slowing it down I think (yes I have many mech since I almost never sell, exception being the CN9 sicne I get the new one, the crappy Jenner cause I hate, and the other Jenner cause I have Sarah).
    The "INVALID" bar in mechbay helps also.
  2. Motörhead
    Tried some fall damage, it's noticeable on heavies and assaults, on the trial HNG for example you loose up to 2% HP each fall.
    That's when you go for it, it's easy counter, but still nice touch. Waiting for JJs heat too.
  3. Regina Redshift
    1,293
    This is a hell of an update. I'm excited, especially about the "Esc" key.
  4. LT Satisfactory
    LT Satisfactory Benefactor
    815
    61
    I'm with Remarius - my 12ersl+4mg nova weeps with the change. +20m means way less to me than going from 60 to 48 backstab alpha.
  5. tfun90
    Hearing this 'relaxing' phrase is something you heard about the previous match maker - and by 'relaxing', they mean slapping shit together for quicker games. If the que times are too long due to too little relaxing, PGI now appears to have the ability to adjust variables on the fly.
  6. Thiak
    Thiak Well-Known Member
    244
    i am more concerned about the group queue
    trying to have some fun with 1-3 friends and getting into a match to face a 12man pugstomp is not what i play this game for
  7. Solahma
    But... the only time you will face a 12 man "pug stompers" is when you have an entire team of groups... so no longer pugs.
  8. Lan
    Lan Mech Wrangler
    1,570
    Edit: My statement was incorrectly remembered, read Thiaks post below.
    It's only as a 4 man lance you can get either the PUG queue or the group/team queue if I understand it correctly.
    If you only drop 2 or 3 ppl, you will never enter the group/team queue. I actually like this setup since it allows for ppl to face others that like teamwork. Of course, you risk getting a full 12 on coms and facing potentially 3 four man lances who doesn't share coms.
    That said, me and a friend dropped together last night and we got into teams with at least one more premade on our side, hard to tell which queue we were in but theory doesn't quite seem to match what is actually happening.
  9. Thiak
    244
    actually, as soon as you play with 1 friend you can end up vs a 12man group
    but still, if you are 2, 3 or 4 premade, if you run into 12man premade with TS you stand pretty much no chance and thats my point
    getting into teams with more premade groups is fine and i appreciate that as well, i just think 12mans should only get matched with other 12man groups
  10. Dr. Danger
    Dr. Danger Advanced Member
    262
    I wonder how many 12man premades are actually out there at any given time; is it statistically relevant or will you face them only once in a blue moon?
  11. Lan
    Lan Mech Wrangler
    1,570
    Correct. Interesting. I really hope the MM can match team compositions better so we don't get a lot of 12 vs 2+2+2+3+3 teams. No way that would be fair as a matchup.
  12. Lan
    Lan Mech Wrangler
    1,570
    So, let's look at poptarting with a classic Highlander?
    (38*1.9)*0,04=2,888
    So the leg has 76 pts of armor and 38 internal, getting 2,89 pts damage each time it achieves 33 ft/s.
    That translates to 26,3 jumps (if damage is taken) before crit open and 13,2 jumps (if damage is taken) before legged. Assume the scale increases with higher fall.
    A feathered landing (braking the descent with JJ's) means more exposed time too.
  13. Blagg Zear
    Why do Lights and Assaults have the same muliplyer of 0.04 while Mediums and Heavies have a lower?
    And the fall velocity is fixed by 30 ft/s. Is that the maximum fall velocity, which is mirrored in the 1.9? So in the end it doesn't matter how high you jump (amount of JJs)? An 1xJJ Highlander suffers the same damage as a 4x JJ Highlander as long as the conditions are fullfilled.
    If that's true it doesn't really work against Jumpsniping. It will only handicap the Agility of Lights. And that's crap imo.
  14. Lan
    Lan Mech Wrangler
    1,570
    Blagg, I'll take a Victor and a spider and jump off a cliff in Alpine. I'll have just a cpl of armor pts (3 pts to check if the damage scales, if it doesn't then I should not get any internal damage) on each and we can check how badly red they get.
    Thinking a running straight flight out south from I9 mountain. Should be at least threehundred feet drop?
    I'll take a premium surgeon along with SLAS to check remaining leg health.
  15. DogSoldieR
    DogSoldieR Active Member
    Yeah, thats how I see it too. Seems to be the Lights getting the bad end of the deal here.
  16. Thiak
    244
    i was running a 4man yesterday and like 1 out of 3, maybe 4 was a 12 man stomp
    maybe it was just because of patchday, but if it stays at this rate i am worried
  17. cs_kami
    cs_kami Benefactor
    434
    I'll say this much, the new patch makes playing the chainsaws closer to the way it was before the patch.
  18. Blagg Zear
    You need to do a different test. Take a Highlander with 1JJ, and then with 4JJ. Jump and then measure the damage you take. Do this again with Lights, Mediums and Heavies. ;)
  19. Solahma
    Lights have much less internal stucture, so the multiplier is greater so it has a noticeable effect still imo
  20. AtomiKpunk
    AtomiKpunk Junior Member
    I played in a group last night whose size varied between 3-5 people. With the exception of I think 3 games our group was routinely pitted against 10 man drops with one getting lucky and syncing an 11th. It was basically a stomp in our favor with the exception of like 1 game. It could be that a few members of my group drug us to a lower ELO bracket and thus the stomping but I dunno under the new MM rules.
