ON1-VA "Oreo" (4x SSRM2, 2x MPLas, 1x LBX10, BAP, XL350)
Thread in 'ON1-VA' started by enileph, Oct 6, 2013.
  1. enileph
    The current build under test. Seems that the high speed, SSRM2, and the shotgun is a good mix. Runs rather cool, but if you really want you can downgrade the MPLas to MLas for some DHS and/or AMS system.
    UPDATE #1: This thing is GREAT! Performs way better than expacted. The LBX10 helps alot by stripping off parts that is damaged by the streaks, and the LLas does pin-pint damage at all ranges. I was expacting this to be just a big daddy of the streakboy, but it does alot more than that.
    I may have to tune the ammo count again though. Current ammo is a bit tight when you are on a rampage.
    My LLas version, in case somone is asking for it. Depending on your own play style you may want to replace one ton of shotgun ammo for streak ammo.
  2. Blagg Zear
    id rather go for Double LLas for the Range.. :rolleyes:
  3. enileph
    That was my other build... I am still trying to find a balance point for that one between the heat and the missile/shotgun feast.
    It was posted in this thread:
    ON1-VA Mean Machine (1x AC10, 2x LLas, 4x SSRM2, BAP XL320)
