I can't play right now since I'm waiting for furniture delivery to show up (fuckers), so I figured I'd amass a quick list of the omnipods and their stats. So, here we go: Head: N/A (all heads the same) Right Torso: (no hardpoints on any RT) Prime: 10% torso turn rate (Yaw) B: 20% bonus to armor C: 7.5% torso turn angle (yaw) Left Torso: (no hardpoints on any LT) Prime: 10% torso turn rate (Yaw) B: 20% bonus to armor C: 7.5% torso turn angle (yaw) Center Torso: N/A, all torsos the same with no hardpoints Right Arm: Prime: 2 Ballistic, 1 Energy, no quirks B: 1 Energy, 2 Missile, no quirks C: 2 Energy, energy heat generation -5% Left Arm: Prime: 1 Missile, missile cooldown +5% B: 2 Energy, no quirks C: 1 AMS, 1 ECM, no quirks Legs: N/A, all the same with a 0.6 add'l structure quirk on each I wasn't too sure how I felt about this mech...it's a 25 ton light that, like the KFX, moves very slowly, which means it's vulnerable to a lot of the new IS metas like the SPL Firestarter or the DRG-1N. It can mount ECM with a single AMS, but that means you're generally going to be making a sniper build, or maybe a NARCer with the C or B right arms. With no torso hardpoint options, you're going to be hurting for damage potential if you use the LA-C, and people will know where to shoot before long to disarm you completely. Interestingly, every one of them comes stock with a cAP already installed, which caught me by surprise. The Prime stock loadout is a joke though, featuring a goofy design with 1 cLRM10, 1 cSSRM4, 2 cMGs, and a cAP. Quite literally one of the worst stock builds I think I've seen PGI put out there. Edit: Worth noting, I guess the cAP is hard wired, so it can't be moved to other mechs, or taken out to free up a ton for a laser. It's in the head for each omnipod. Edit 2: Stock, they put almost no armor on the legs and arms...so expect to strip something if you want to have any armor at all. With the ECM and a single cERLL, you have a mere annoyance of a paperweight. But you should be able to max armor without the cERML and cAMS...
TBH I've been playing with mine and they jump extremely well but that's about their advantage. The ECM arm costs you half your armament and that really hurts but then max armour really hurts too..... weird mech. Take the shock absorption module... you do NEED it. Practice jumping on the test grounds before you drop properly - you will thank me.
I use the Prime LT and the C RT, for the torso turn rate and torso turn angle bonuses. Haven't needed the armor strength bonus yet -- have yet to even lose an arm or a leg...
5/5, Thank dude. Was about to do this. B or C side torsos. The ECM is not as good as expected. You have to put all your weapons in your RA then. Not a good thing.
Do you think the armor bonus applies to all mech parts or just that particular side torso? I assume it's the whole mech and that makes it a complete no-brainer to pick over the others in my opinion.
Just a note on the original poster's inference that PGI comes up with silly stock builds. The stock builds on mechs are based on the traditional Battletech rules. The Mist Lynx Prime is no different. For example, see: http://www.sarna.net/wiki/Mist_Lynx Not arguing that the stock build isn't useless.
I think the bonus only applies to the torsos. My reason for that is that it seems to specify what is getting the bonus in brackets.
Probably right about the armor bonus only applying to it's side torso. In that case, it makes it a little tougher of a call on which pod to take, as arms blow off before ST it seems to me.
