new build A whole lotta blue lovin' from a long way away. The lower arm actuators from the prime arms allow even more lateral movement for the pew pew. Edit: 2014-09-23 updated the title with special equipment Edit: 2014-09-23 updated to latest build as per suggestions old build
I ran 4-7 cERLL on the timberwolf with more and less heatsinks. Makes a good joke build but definitely doesn't have the cooling rate to be a semi-serious build. You should max out at 4 cerll.
arms are just too low to pull this off. one of the better builds for a summoner because...well... there are no other choices, but this really doesn't translate in the mad dog.
