MDD-A "The Duke" (1x cGauss, 1x cERPPC, 6x SRM2)
Thread in 'Mad Dog Omni Builds' started by nedo, Sep 28, 2014.
  1. nedo
    nedo New Member
    I'll share my MDD builds, I didn't find any here that I directly wanted to use. Here's my take trying to make good use of the only benefit that the MDD has, that is 6 missile slots. (Note: you can build them all on the prime if you want to use the bonus, just copied the chassi I use them on here)
    MDD-A
    This one has the long range capability of the Stormcrow meta, and in addition uses the 6x slots with one SRM2 in each to produce the effect of 2x SRM6 but with less spread. Firing them in one group creates some ghost heat but not much. Even though there are few heatsinks on this build, it runs cool.
    MDD-B
    This build tried to max the SRM 1-group alpha without using artemis and without triggering ghost heat. 2x SRM4 + 4x SRM2 has little spread and no ghost heat. It's then filled with lazors and heat sinks.
    MDD-P
    This is rather standard and probably in one of these posts here. Uses 6xSRM6 because you can... and then just try to keep it as cool as possible. It works, but runs a bit hot. You may be able to add one more ML or TC or even both once elited, but its enough with 4 for me right now.
  2. Aylek
    Please create a single thread for each loadout. Makes discussing them much easier. Thanks!
  3. nedo
    nedo New Member
    Ok, splitting the first 2 and scratch the 3rd, its not unique enough... :)
  4. nedo2
    nedo2 Junior Member
    Thought I would put a fancy screenshot here from an awesome game but didn't get any really outstanding score while skilling this build. However, it did perform very well so I'll paste in the stats row, it included many 600-800 dmg and 1-3 kills. Average was 3.08 k/d ratio and 440 damage/match. Over all it's a bit like the Stormcrow, but when you get challenged by a red light you can hit him with a tight SRM12 over the knees to send him running and with the gauss in the ass on his way out. :)
    MAD DOG MDD-A 29 17 12 1.42 40 13 3.08 12,753 58,544 03:10:01
    After skilling them dogs its clear that I performed the best in this build over the SRM36 and the lazor-builds so I can highly recommend it if you didn't try it out!
  5. S Morgenstern
    S Morgenstern Star Lord
