A build designed to grind out that xp with the A using full omni-pod bonus. I personally feel you can do better by sacrificing the omni-pod bonus for other arms with more energy hardpoints (thus carrying TAG AND energy weapons), but decided to theory-craft this thing for those who like running with the correct pods. Basic idea is pretty simple: the LL and UAC5 act to discourage harassers and can double as direct-fire out to long range against targets of opportunity, though I don't recommend using UAC ammo for this outside the optimal damage range as you only have three tons of ammo. You have enough ammo and TrolLRM5s to keep up a steady rain when you get the chance, or link-fire for larger salvos as needed. Recommended Weapon Groups: 1) cUAC5 2) cERLL 3) LRM5s (chain-fire) 4) LRM5s (linked) Easy enough to drop armor from torso and arms if you feel more ammo is worth the risk. If you're using the C-LRM 5 cooldown module and are willing to sacrifice the potential to LRM-30, you can this instead:
Which breaks the omni-pod bonus, which is the point of the build. While technically enough for continuous fire, it's not actually enough for uninterrupted chainfire, for which you still need 6 unless you have a cooldown module. If using the LRM cooldown module, it's enough to change the build up. Editing OP to reflect this.
All these builds look great but the UAC-5 could be replaced by an LBX-2 or UAC-2 and the CERLL could be replaced by a CLPL or CERPPC.
