MDD-A "Mad Dog in Heat" (6x cSRM6, 5x cerML)
Thread in 'Mad Dog Omni Builds' started by P, Jan 26, 2015.
  1. P
    P Well-Known Member
    This dog is in heat
    Playstyle:
    Do not in any circumstances alpha strike
    if you are a dog in heat, please do so.
    Mouse1, SRM6s Volleys
    Mouse2, ChainFire the lasers only in volley when you see feat accordingly to your heatscale
    Mouse3, Chainfire SRM6s
    If im almost in heat, i will chainfire muh lasers maybe three times or twice or even less or backoff to cool off first
    with 107 face melting damage, you should know that you are not a Front-liner, and with the squishiness that you have, you are a rabid dog that comes out in your supposedly wolfpacks that holds the most venomous bite.
    You will find yourself be firing muh lasers most of the time in order to save your srms for those miracle moments especially if you lack the Artemis.
    This build may hold potential but it is your fire disciplines that will make this dog shines during the pounding of the bitches. Unless you met a pair of golden towering direwolves humping each other with one on top another, then you should hide you tails between your buttcheeks and run.
    p.s. gardenhose version of maddog should be pissing blue pee allover the place
  2. enileph
    Not enough missiles, waaay not enough.
  3. Axex
    Axex Star Lord
    46
    11 folly's of cSRM36 is a bit low indeed.
