The thing is, you might say, that you'd be dancing with the spectre of heat since there are more than 2 large lasers. BITCH PLEASE. You have 9 clan lasers here. You think that extra 7.3 heat is going to matter when your heat sinks are already molten!? Yes? You're right. But, you can alpha while on resting heat, using a far removed weapon group so you don't do it accidentally. That nets you 81 pinpoint damage, and if you're under 30% heat (map dependant) you can safely fire 2xLPLs and 6xERMLs at once. The nitty gritty is up to you, pilot, but it's your duty to laser their rave parties, and laser them well.
