Work in progress to put some of the long-range damage farming builds and information in one spot. Weapon Information cLBX2 Shots per ton: 120 (+10/skill node) Range: 900/1800 M Velocity 2000 cAC2 Shots per ton: 100 (+10/skill node) Range: 900/1800 M Velocity: 2200 cUAC2 Shots per ton: 100 (+10/skill node) Range: 810/1620 M Velocity: 1800 cLBX5 Shots per ton: 48 (+4/skill node) Range: 720/1440 M Velocity: 1700 LBX2 Shots per ton: 120 (+10/skill node) Range: 810/2430 M Velocity 2000 Assault Builds DPS Bane-1 Heat -10% 9xcLBX2 (13 tons ammo) 7xcLBX2, 2xcUAC2 (15 tons ammo) 6xcLBX2, 3xcLBX5 ECM Bane-6: 10xcUAC2 Dire Wolf DPS focus DWF-WM: 8xcLBX2 Cooldown -10% MechDB - DWF-WM(S) Velocity Focus DWF-UV: 8xcAC2 https://mwo.nav-alpha.com/mechlab?b=10e1016e_DWF-UV Velocity +10% Heat -5% ECM, JJs DWF-C Cooling DWF-Prime Heat -7.5% Laser duration -5% 8xcLBX2, 1xcERLL https://mwo.nav-alpha.com/mechlab?b=faee3311_DWF-PRIME Head can be changed out for extra armor and a missile hardpoint, an energy hardpoint, or 25% radar derp. cERLL - 4 tons 1xcLRM10+1T ammo - 3.5 tons 1xcLRM5+1T ammo - 2.0 tons Stone Rhino (JJs) 8xcLBX2 4xcLBX2, 4xcUAC2 Executioner Sovereign (JJs) Ballistic Cooldown -17.5% LBX Spread -20% JJ Burntime +15% 2xcLBX2, 4xcLBX5 https://mwo.nav-alpha.com/mechlab?b=9d7d8366_EXE-B-CLGD 6xcLBX2 https://mwo.nav-alpha.com/mechlab?b=a432609a_EXE-B-CLGD 6xcLBX2, 2xcERPPC https://mwo.nav-alpha.com/mechlab?b=23869a18_EXE-B-CLGD Fafnir Juggernaut 8xLBX2 https://mwo.nav-alpha.com/mechlab?b=42ea9acf_FNR-J Mauler Cooldown -20% Range +10% 6xLBX2, (ERPPC) https://mwo.nav-alpha.com/mechlab?b=5758bb2c_MAL-MX90 https://mwo.nav-alpha.com/mechlab?b=33636ba3_MAL-MX90
