JM6-DD "When in Doubt, Take it ALL!" (1x AC10/AC20, 1x UAC5, 1x AC5, 1x AC2, XL200/225)
Thread in 'JM6-DD' started by Falconium, Apr 17, 2014.
  1. Falconium
    Ok, so after posting my "Spice of Life" Jagger-S, I started to wonder: "What if I tried to fit 4 different ballistic types onto a single Jagger?" So I did a bit of brainstorming on Smurfy's, and this is what I came up with.
    Granted it's slow, and low on ammo and armor, but seriously: Can you imagine what it would sound like having all those different ballistics firing at once, all out-of-sync with each other?!
    Alternate version, which replaces the AC10 with a 20. It actually goes faster(!), but has even less ammo and armor.
    The first build will work on both the DD and the S Jagger variants. But the alternate AC20 version needs to be able to put three ballistics in one arm, hence the reason for building them on the DD variant.
  2. RA2lover
    RA2lover Active Member
    88
    this seems to benefit with a heavier chassis.
  3. Falconium
    I honestly hadn't thought of trying this on the Phract-4X. I was in Jagger mode! :p
    Gotta say, it looks much more balanced so far as armor goes, and it even has an extra slot you could put an extra ton of ammo in by dropping armor (which is still fairly decent at 368).
    It doesn't fit the AC20 variant though. :(
    So yeah, the Phract-4X is definitely a better choice for the AC10 version; but if you want to take the AC20, you have to stay in a Jagger-DD.
  4. epikt
    I like that!
  5. Cpt Chattahah
    Ehhhhh? EHHH?????
    Easily over 1k damage with the extra ton of ammo. The LBX gives you more close range ability to chase off the lights, and, the crit power to finish. Still a crazy idea, but, could be some fun! :D
