Fun build for the DD, I would rate myself as an average player but with this build I usually run over 500 and got an 800+ on one round,the ac 2 helps keep dmg up when your UAC's decide to jam.
High sustained DPS but that's because it fires so little it has trouble to heat up, and that's before you take into account that UAC5s jam most of the time :/ Way too little damage for a jager. I'd prefer to have a second AC2 to keep up the deeps, turning it into a pretty regular 2xAC2,2xUAC5 build. I feel that with only 1 AC2 you're lacking a lot of damage potential and that's what jagers are all about: deal as much damage as you can before they kill your side torso(s). I'm also a big fan of asymmetrical builds, for convergence and exposure reasons. It's a lot easier to lead and hit the same component with AC2s from the same arm than those on different arms, though you run the risk of having waste ammo in your mech that's only there to explode. I put in an XL255 engine because it's more common than the XL260, though the XL260 comes with the mech so you could eventually drop 8 more armor on each arm (arms have tiny hitboxes, will barely ever be shot) and fit the stock engine. It's also a good idea to check out the 3xAC5,1xAC2 and 'Hoser' builds in the JM6-S section of the forums, which offer better solutions to 'what to do when my UAC5 jams'.
