JM6-A "The Jagerbomb" (2x MPlas, 2x AC5, 4x SSRM2, AMS, XL250)
Thread in 'JM6-A' started by Pres Rakete, Mar 20, 2013.
  1. Pres Rakete
    Pres Rakete New Member
    If you have any ideas of improvement let me know.
    See you on the Battlefield.
  2. Mythweaver
    Mythweaver Advanced Member
    400
    Do you really need 150 volleys of SSRM missiles? I really think that half of that amount would suffice and the difference in weight could make you go faster, just a thought.
    Mythweaver.
  3. Pres Rakete
    Yeah. You are propably right. I just hate to run out of ammo.
  4. Torabayashi
    Torabayashi Junior Member
    44
    The XL 255 weighs the same as an XL 250, there's also no mech that can run a 250 that can't 255. It's a big expense if you already have the 250, but otherwise there's no reason to buy the smaller engine.
    Also, I'd consider downgrading the pulse lasers to standard, the mech runs quite hot as it is. Use the extra tonnage for heatsinks and/or more armor for your legs.
  5. The Verge
    Nice build, but I like some speed with my Jager. Lets me keep up with light mechs. Also, why no BAP for those streaks? lets you kill ECM'rs too.
  6. Blagg Zear
    Hi there, i gave you 3 of 5 stars. Your Approach has several flaws.
    Here the bad things:
    1. low Cool Efficiency
    2. low speed (by using XL Engine very bad!)
    3. relative low Armor
    4. wasted tons for too much streak.ammo
    5. ac/5 ammo not very much, can run dry fast
    At first Glance good Alpha Strike Power, but SSRMs rarely fire with your other weapons at same time and they do spread, so finally bad Alpha Strike Power
    The good things:
    1. versatile Weapon Setup
    2. Good Defense against Lights
    Blagg Zear
  7. Cpt Chattahah
    My personal take is to go SRMs over streaks. Too easily disabled and for the weight, pack less punch. I prefer the shotgun effect.
    4xSRM4 will do some good damage at close range if you wait for the right shot, you can usually poach AMS or ECM off an ally and if not, with a 300 engine, can get to cover fairly easily. Also, since a Jager's cockpit is basically non-existent (I've lost a Jager to a cockpit shot once and I run Jagers often) you can drop a lot of armor. I only run with enough to cover me from LRM and laser splash damage. Also, side torso slots will kill you 9 out of 10 times in a Jager with an XL, so, I usually only run ~60 armor in CT.
    The JM6-A is my least favorite Jager, but, I did have some fun with The Shotfun. (as follows) :D
    Just my take on things. Not a fan of streaks and gotta keep some speed. Drive on, Warrior!
  8. Blagg Zear
    hey Captain, i like you first config! Very decent, high speed, i think its very viable for 1on1 fights. Thumbs up!
    Blagg Zear
