Hard hitter at any range. 30 Missile barrages (+ TAG) and ERLLaser will chew up hostiles in a hurry. Common enemy pilot mistake, mistaking you for a "weak at short range" LRM boat. But 1 or 2 AC20s across the brow will have them running if not killed entirely. This boasts the highest grade engine that a Highlander can equip. It is the best weapon against light mechs that you ever find. With quicker turning radius and fast torso twists, you will have no problem keeping even the fastest mechs within your sights. It takes some practice learning how much you need to lead them, but I have killed MANY light mechs with 1 sometimes 2 AC20 shots. I have a 2.8 rating in the kills / death ration on the profile / stats screen. But you be the judge on whether it is right for you.
I played around a bit with it, but still kept the fundamentals. It includes the 1 JJ you suggested. Swapped the ERLLaser for EEPPC with I really like better because of distance.1 LRM Ammo and 1 AC Ammo were removed, but it's still a monster. What I like most about it is this. The best Engine available. The maximum amount of armor. The longest range and most damaging energy weapon (PPC / Laser) The most powerful Autocannon. And then the 30 missles and you are carrying your very own tag (still gives you TAG / NARC bonus) I just love it.. Thanks for the suggestion of the JJ, it can be a game changer It takes advantage of every ton available and every slot is filled with goodies
