HGN-733C Full Frontal (1x AC20, 3x SRM6+A, 1x LLas, 1x JJ, STD300)
Thread in 'HGN-733C' started by JadedDemon, Nov 5, 2013.
  1. JadedDemon
    JadedDemon New Member
    http://mwo.smurfy-net.de/mechlab#i=72&l=93542e2a249084e80b2c36ff931d637cb808d5f7
    I thought id share my favourite Highlander build with everyone. I know its so similar to many but I tried to find this one, and while everything seemed close I found from tweaking and playing this many times the result is this.
    Its a classic brawler. Sit back / pop-tart with your LL until the fight becomes more personal. Then basically gets in close and move around the enemy heavy/assault to use him as a body block against enemy fire. Offload AC/20's and SRMs as quickly as you can. Using the LL continuously will result in overheating, and is not intended to be used much in the brawl, so use it as much as your heat allows. I have yet to meet a mech that can outlast the heat from just the AC/20 and SRMs. They simply just strip the enemy mech raw in seconds. Typically I just go for the core but sometimes on Atlas' I strip the shoulders first because its easier.
    The LL, like a lot of other builds here, can be replaced with 2 ML's and you gain 3 tonnes to add extra ammo. I was not too impressed with this as a) there is only 2 slots for extra ammo, b) 2x ML produced slightly more heat for slightly more damage with a significant range drop. You got Close Combat covered. The LL allows you to have some potential mid / long.
