HBR-P "LAZORS!" (1x cERLL, 6x cERML, cECM, TC1)
Thread in 'Hellbringer Omni Builds' started by neathdrawls, Dec 2, 2014.
  1. neathdrawls
    neathdrawls New Member
    Weapon Group 1: cERLL
    Weapon Group 2: LT 3x cERML
    Weapon Group 3: RA LA 3x cERML
    Slightly surpised to not see this build here. Even though it is not as wub wub as the 6 cMPL build, this is the build I prefer to use as there is moar lazors! Got so tired of finding builds and just grinded all three Hellbringers with this setup. Racked up quite a few games with 600ish damage and a couple of kills.
    Head mounted cERLL gives you poking power at long range, with the perks of it being high mounted. Anything you can see, you can shoot.The 6 cERMLs give you loads of heat, but the range and the almost convergence of the lasers are a plus. And of course, the damage, at 53, nothing to be kidding about, even though there is the burn time,
    Usually start alpha-ing things you can see, with the cERLL have almost similiar cooldown and beam duration to the cERMLs. Almost smiliar. Range wise, the max range of the cERMLs is good enough to be doing some damage at the effective range of the cERLL.
    Best part of this build, 26 cDHS! Un-elited, could give you 3 alphas and the cooldown speed of this machine is insanely fast. So fast that firing the cERLL on it's own kinda doesn't impact the cooling down. And of course, mandatory ECM.
    And the bonus of having the right side of the whole mech as a shield, so twist away, with the hotfix already in play (which might warrant a look at the armor values again). Of couse, you could drop the RA cERML for another DHS, but I rather have the extra lazor.
    Please do critique the build, and do let me know your opinions, good or bad.
