Since noone had posted this... use right side as shield, laser vomit with the other. Used B pods for maximum quirks on the shielding side. May or may not end up using TC1, need to elite it before I decide on that one.
I run about the same built, I just switch the C-MLAS for CSPLs. Makes it a bit more of a closer range fighter, but it gives you better heat efficiency, better dps, and not that much worse firepower
