HBK-IIC-A (2x cLPL, 6x cERSL, 1x JJ, cXL225)
3/5,
Thread in 'HBK-IIC-A' started by Sturmkraehe, Dec 16, 2015.
  1. Sturmkraehe
    Sturmkraehe New Member
    The good Hardpoint-Position of the two cLPL beside the Cockpit allows you to fire on Long Range and the 6 cERSL are verry good for Short-Range-Defense. With a little bit of Heat-Management this Loadout works fine.
    Greetings
    Sturmkraehe
  2. Ragnar RedHawk
    Ragnar RedHawk Well-Known Member
    141
    You forgot to put the engine size in the title. Unless that's not a requirement...
  3. Skaav
    Skaav New Member
    Weapon Range has no Synergy at all, while still running as hot as more sensible Weapon combinations with a similar Alpha, also very slow and only 1 JJ. Running DHS in quasi unarmored arms is just a terrible idea aswell.
  4. enileph
    Actually 1 JJ is often good enough. JJ is mostly for turning, going along glitched small terrain obstacles and going up hills.
    But yes I agree that it is waaaay too slow for what it is, and bad idea to put stacks of DHS in srtipped arms.
    I guess the weapon range is ok if you don't plan on using them together. I would not do it this way though.
    My suggestion: buff armor up one shield arm and put DHS there, upgrade engine. You need to go fast if you use SL.
    Not what I would use but each to their own.
  5. Blagg Zear
    I actually like this build and it's not as bad as the first rating says. In my Executioners/Gargoyles i had high scores with this Lasercombo! Just try it out before judging. LPLas for mid-long range. In CQC just Alpha for quickkills. The only thing i dislike is the limited space for placing the DHS.
    Also it's a bit tricky to place the LPLas on the high Weaponslots. Try putting in the ERSLas first.
    Here is my Mod (with a TC1!):
  6. enileph
    Close to what I would be doing, a bit more armor on the arms.
    I thin a larger engine would be good also, you can get up close easier, and that is a conclusion from my games of running SPL on this model.
    As I say the weapon combo is ok, I just prefer SPL over ERSL.
    Maybe a cXL255 for more speed?
  7. Skaav
    Skaav New Member
    Didnt mean to be a dick with my rating, but the original Build just had major flaws (armor, engine, DHS distribution, in my opinion Wepon range as well).
    Also could somebody please elaborate how this weapon combination makes any sense on something this squishy?
    As I said, sorry for coming of as a bit of a dick maybe, its just I really cant see the upside of this Build.
    P.S. : for me, the highest mounted wepon is always the one I equipped first with the HBK IIC
  8. Blagg Zear
    Here is a another Attempt for maximum Mobility:
