HBK-4P "Knifeback" (9xML, STD270)
3 ratings
Thread in 'HBK-4P' started by Gambino87, Mar 31, 2013.
  1. Gambino87
    Gambino87 New Member
    I'm sure people out there dabble with different variations. Check out these breakdowns for alpha strikes.
    These all include the Elite efficiencies unlocked.
    9 ML - Total heat 49.66, Ghost Heat 13.66, 45 Dmg
    8 ML - Total heat 39.60, Ghost Heat 7.60, 40 Dmg
    Forest Colony
    8 ML, 19 DHS - 9.2 second cooldown time
    8 ML, 18 DHS - 10 second cooldown time
    8 ML, 17 DHS - 11 second cooldown time
    9 ML, 19 DHS - 12 second cooldown time
    9 ML, 18 DHS - 13 second cooldown time
    9 ML, 17 DHS - 13 second cooldown time
    Alpine Peakes
    8 ML, 19 DHS - 7.4 second cooldown time
    8 ML, 18 DHS - 7.8 second cooldown time
    8 ML, 17 DHS - 8.2 second cooldown time
    9 ML, 19 DHS - 9.2 second cooldown time
    9 ML, 18 DHS - 10 second cooldown time
    9 ML, 17 DHS - 11 second cooldown time
    Caustic Valley
    8 ML, 19 DHS - 11 second cooldown time
    8 ML, 18 DHS - 12 second cooldown time
    8 ML, 17 DHS - 13 second cooldown time
    9 ML, 19 DHS - 14 second cooldown time
    9 ML, 18 DHS - 15 second cooldown time
    9 ML, 17 DHS - 16 second cooldown time
    EDIT: I think what can be tooken away from this is, you can trade 3 seconds of cooldown for 5 extra alpha strike damage. If you specialize in hit and run, I think the 5 damage is worth it. And also, paying 1 second of cooldown for the BAP info gathering boost + the module info gather boost is worth it.
    Sure it's not pinpoint like an 2xAC20, but if you miss you can course correct your shot and at least score some damage. A well aimed shot will score you more damage than 2xAC20. And in HPG manifold your opponent may not even understand what just hit them until its too late.
    enileph likes this.
  2. enileph
    Bumping up the classic builds.
  3. Madgoose
    Madgoose Well-Known Member
    I'm using this build with a STD260 - great output, much fun!
    MadTerrapin likes this.
  4. MadTerrapin
    MadTerrapin Junior Member
    Love the Hunchie and glad to see more of them around.
  5. don Zappo
    don Zappo Advanced Member
    428
    46
    In the current era of LRMs, don't underestimate the value of a good AMS. This works particularly well as this mech makes an excellent escort mech, so you can help keep your fatties alive while providing fire support. Plus, for how battles typically go with this mech you can afford to lose a DHS as you actually get a 10% reduction in heat. Do note, however, that if you find yourself in a magical spot where nobody is shooting at you and you can just crank on the sustained fire, this mech actually runs hotter now.
    Additional Armor (RT) +18
    Additional Structure (RT) +12
    Medium Laser Cooldown +15%
    Energy Weapon Cooldown +7.5%
    Medium Laser Duration -15%
    Laser Weapon Duration -7.5%
    Energy Weapon Heat Generation -10%
    Torso Yaw Speed +37.5%
    Torso Pitch Speed +10%
  6. don Zappo
    428
    46
    Accept no substitutes. This is the way to run this mech. If you seem small lasers or pulses on this you're doing it wrong!
  7. B8hunter
    B8hunter New Member
    This is my go to build for the 4p 9 lasers firing in groups of 4, 3 and then the 2 on the arms. the left side makes a great shield if need be as well.
  8. epikt
  9. B8hunter
    B8hunter New Member
    You'd post it to if you keep getting 600+ dmg games also that post is 2 years old anyway
  10. Michael
    Merge time
  11. tfun90
    I'm sorry, is this guy who doesn't understand the concept of threads explaining how a weak side shield works?
    PS your weapon groups are wrong.
  12. dranozir
    One of the best hunchback build.
  13. skribs
    skribs Min-Max Maniac
    1,690
    Just started running this. Is Alpha-Hunch-Arms-Head still the go-to- weapon grouping?
  14. The Verge
    Updated build for the Civil War
    With AMS+TC3
    With TC4
