Grid Iron "Iron Fist" (2xLPL, 1xSRM6+A, 1xML, 2xMG, STD235)
Thread in 'Grid Iron' started by Blagg Zear, Jan 7, 2014.
  1. Blagg Zear
    Good Speed with Top Cooling and superb DPS even without the MGs
    Blagg
  2. Aylek
    This was the first build a friend of mine used after purchasing the Grid Iron right after the servers went back up. I liked the idea, but take a slightly different approach by using ERLLas. Standard LLas are probably better as soon it gets into brawling, though.
    Nevertheless, here's my variant. Comparing those two I'd remove 1 DHS from your build to add that second ton of SRM Ammo. And your leg armor... don't know if I'd like it that way.
    Replacing the ERLLas with standard versions bumps the cooling efficiency to 47%.
  3. Michael
    This is the Gumpy build version of this loadout
  4. Blagg Zear
    Changed back to STD Version for BM :p
